Archived:cRIO 900x STATUS LED Solid
Updated Jan 4, 2019
National Instruments does not actively maintain this document.
  • cRIO-9002
  • cRIO-9004
The STATUS LED of my cRIO 9002/9004 is solid
As reported in the user manual, a solid STATUS LED indicates a corruption in the flash memory card on the controller. You can format the hard drive from NI MAX in order to try to fix the issue.
