Saving Data from Data Portal to Excel Format
Updated Aug 9, 2018
  • DIAdem 2012
  • DIAdem 2015
I need to save data from Data Portal in DIAdem to Excel format *.xls, but I am missing this option in Save As dialog.
Additional GPI extension needs to be registered in DIAdem to have a possibility save data from Data Portal in Excel *.xls format. Select Settings»Extensions»GPI Extensions and register the file GfSExcel.dll.
Option for saving data in Excel format is going to be add to Save As dialog after restarting DIAdem.
This procedure works only in DIAdem 32-bit as this GPI extension is only available in 32-bit version.
