Is It Possible to Implement a Watchdog on a USB cDAQ?
Updated Mar 19, 2019
  • cDAQ-9171
  • cDAQ-9174
  • cDAQ-9178
I have a USB cDAQ chassis and I would like to implement a watchdog (for example I need a pin to keep the high state when the USB cable is unplugged), can I do it?
The DAQmx driver has Watchdog functions but you can use those only with cDAQ 9185/89 or the 9188XT which are not USB but Ethernet versions, so it's not possible to do it with a USB cDAQ chassis.
