I am using a PXI (or PXI Express) controller, which runs PharLap ETS Real-Time operating system. In NI MAX, the device is present with the status: Connected Safe Mode (Software Error). What should I do to recover my PXI(e) system?
According to the Configuring Software and Hardware Firewalls to Support NI Products document, confirm that the following ports are open:
If you are assured that all necessary UDP and TCP ports are configured properly and the issue still persists, perform additional steps:
