View Block Diagram Elements as Icons
Updated Jul 18, 2018
I want to change how my block diagram terminals are represented. Currently, they are a mix of larger and smaller terminals, but I would like them to all be the same format.
To change how terminals are represented in the block diagram: right-click on the desired terminal and toggle "view as icon" in the drop-list.
If you want to avoid having to do this every time you make a new terminal, you can toggle: Tools > Options > Block Diagram > Place front panel terminals as icons.
New terminals created should match this setting.
