NI CAL-4353 Verification Procedure in LabVIEW
Updated Jul 6, 2018
  • PXIe-4353
  • CAL-4353
I am trying to calibrate a CAL-4353 and am unclear about how to open and NI-DAQmx Calibration Session on my device using LabVIEW. What does this entail and how can I get started?
Verification of a CAL-4353's operation involves initializing an external accessory calibration in LabVIEW and taking resistance measurements of the devices CJC terminals per the instructions in the CAL-4353 Calibration Procedure. See the attached block diagram for an example of the programming flow for verifying a CAL-4353's specifications:
Note that calibration / verification of the CAL-4353 in Calibration Executive is currently not supported.
