Visual Studio Hangs When Using NationalInstruments.TestStand.Interop.API
Updated Jul 4, 2018
  • TestStand
Programming Language
  • C# .NET
I am trying to use the NationalInstruments.TestStand.Interop.API (.NET interop assemblies for the TestStand API) to generate sequence files. I am able to correctly generate sequence files but there appears to be an issue using Visual Studio after a finalize routine is called. Visual Studio seems to hang only when I have created a new engine.
TestStand Engine needs to be launched in its own AppDomain to properly load and unload the unmanaged code that the TestStand engine is based on. You must not define a destructor because unloading AppDomains and releasing unmanaged code references does not work in a .NET destructor.
