My Vision Assistant Steps Keep Repeating in Vision Builder for Automated Inspection (VBAI)
Updated Jul 12, 2018
  • Vision Builder for Automated Inspection
I'm trying to build an inspection step where I use filtering from Vision Assistant. However, everytime I step through the step, either forward or back, it applies the filter on the image again. How can I have it only apply it once?
This is expected behavior if the acquisition state is separated from the filter state.  If the analysis steps are in a separate state, it will keep doing the filter steps on the filtered image since the altered image is being stored in memory.
To get the behavior you would like, you need to have your acquisition step in the same state as your analysis steps.
