Each of the tables below contains a description of the tokens that may be modified in the LabVIEW.ini file and NI-RT.ini files. You can add specific tokens based on your requirement. For detailed information on these tokens refer to the attached Excel file in this document. The Excel document additionally explains the value to be set, default values, the INI file to edit, the applicable version and the OS for each of these tokens.
- Listed below are the RT specific configuration tokens that you can include in the
NI-RT.ini
file.
Token and Default Value | Description |
LegacyTickTimerPeriod | When TRUE, use a fixed tick timer period of 1.0007 ms; otherwise dynamically adjust the tick timer period to give an average period of 1 ms |
RTTarget.DiskCache.Enable | Enable/Disable the cache. Default is TRUE. All of the rest of RTTarget.DiskCache.* are ignored if RTTarget.DiskCache.Enable is false. |
RTTarget.LaunchAppAtBoot | Enables the startup application |
RTTarget.StartupVIs | VI to launch on startup (similar to startup app, but just a VI) |
RTTarget.TimeZone | Disable day light savings on the RT target. |
SendBufferSize | Legacy token for LabVIEW RT 7.1.1, replaced by SocketSendBufferSize for 8.0 and higher. Still understood by 8.0 and higher. SocketSendBufferSize overrides the value of this token. Max value is 65535 |
SocketRecvBufferSize | Defines the size of the LabVIEW layer socket receive buffer. 4096 is the default value but we override it to 65535 on targets that have more RAM like PXI, CVS and the desktop |
SocketSendBufferSize | Defines the size of the LabVIEW layer socket send buffer. 4096 is the default value but we override it to 65535 on targets that have more RAM like PXI, CVS and the desktop |
StdOutRedirectionFile | Specifies the path to a file to which screen output (specifically anything printed to stdout) will be logged instead of being displayed on the screen. If the token is not present, the output will be printed to the screen as usual. |
TraceEthernetDriverLoading | When TRUE, prints out information about the Ethernet driver loading process to the target screen. |
- Listed below are the LabVIEW configuration tokens that you can include in the
LabVIEW.ini
file.
ExecEngineSelectPrompt.NetworkName | List of recently targeted IP/network names (prior to 6.1, this only stored a single PStr value) |
RTPauseAfterDLInfoDlg | Pauses the download progress dialog after download is complete so that user can inspect the verbose dialog (does not affect simple download dialog) |
TargetMemInfo | Operate >> RT Engine Info brings up memory usage dialog. |
Note: The LabVIEW.ini file is found in the ~ProgramFiles\National Instruments\LabVIEW (Version)\. The NI-RT.ini file is found by using ftp. ftp://TargetIPAddress.
