Supplying Voltage with a PXI Chassis
Updated Aug 17, 2018
  • PXI Chassis
  • Power Supply
I have an amplifier that needs to be sourced with 24 V to operate. Can PXIe-1084 or any other chassis supply 24 V?
National Instruments PXI chassis are unable to supply voltage because they do not have external excitation terminals.
You can use a Programmable Power Supply to provide the desired voltage. The PXIe-4112 can provide up to 60 V.
