NI VNA Time Domain Analysis Licensing
Updated Jun 29, 2018
  • PXIe-5630
  • PXIe-5632
  • NI-VNA
I have several National Instruments VNA devices. I want to activate Time Domain Analysis on them but do not have a license. How do I get a license for each VNA?
You need to purchase a license for each VNA device.
You can purchase the Time Domain Analysis (TDA) option when you buy your VNA using the following part numbers:
PXIe-5632 with TDA option: 782299-02
PXIe-5630 with TDA option: 781219-02
Alternatively, you can purchase the license separately using the PN 781800-01. This is useful if you want to activate an already purchased VNA device. It works with both PXIe-5630 and 5632.
Note: Activation of Time Domain Analysis is done on the hardware itself. You will not have to activate it for the hardware again once it's been completed. As a result, you can change controllers and it will still be activated.
Follow the Time Domain Analysis for NI Vector Network Analyzers Activation Instructions to activate TDA.
