Using a Differential Trigger Source with a CameraLink Frame Grabber
Updated Nov 6, 2018
  • PCIe-1427
  • Camera
  • Vision Acquisition Software
  • NI-IMAQ
I am using a differential source to trigger my Camera Link camera to acquire an image. How should I set this up?
If your frame grabber has an encoder input (such as the PCIe-1427), you can wire the trigger source into the Phase A ± or the Phase B ± inputs. You will then want to configure your camera to look for an external trigger source. The frame grabber will then look for a trigger signal from either the TTL trigger lines, or from the Phase A/B lines.
You can find information on the pin mappings for the Phase A/B lines in the user manual for your specific card.
