Archived:How To setup A Trigger With A PFI Connection On A SC-2345 ?
Updated Jul 2, 2018
National Instruments does not actively maintain this document.
  • SC-2345
  • NI-9234
How can I setup a trigger to start an acquisition using the PFI connection on a SC-2345 connector block.
The connector block SC-2345 has a Source PFI connection that can be used as a trigger which is located on the pin 37.
This information can be located on the manual of the connector block SC-2345 on the page 2-2 where you can find a table with the terminal block I/O connector pin assignments.
