What is the Pinout for the SHB 12X-B12X Cable with FlexRIO?
Updated Jul 9, 2018
  • SHB12-B12X
  • NI-6583
  • PXI-6561
  • PXI-6562
I have an NI 6583 FlexRIO Adapter Module (FAM) that I want to use with an SHB 12X-B12X cable, but I don't know the cable pinout. The documentation mentions that the pins are reversed, but is there a schematic for this cable?
You can find the pinouts in the NI High-Speed Digital Waveform Analyzer/Generator Getting Started Guide under Appendix A, Figure 18. A side-by-side comparison of the pinouts for an NI 656x device showing how the pins are reversed by the SHB 12X-B12X cable is below.
Although the numbering is different on both ends of the cable, the pins with the same signal names (Pin 2 - PFI_1 and Pin 72 - PFI_1) are connected through. Therefore, pin 2 is connected to 72 (PFI_1), pin 3 to pin 71 (PFI_1*), pin 35 to pin 39 (DIO 7), etc.
