Does LabWindows™/CVI™ Support Building Large Address Aware Applications
Updated Oct 9, 2018
  • LabWindows/CVI
I have a 64 bit operating system and I need to build a Large Address Aware application using LabWindows/CVI. How can I proceed?
LabWindows/CVI does not support the build of Large Address Aware applications. You can only define your application to be built as a 32 bit or a 64 bit application. However, if you want your 32 bit built application to be Large Address Aware, you need to run the following command using the Visual Studio command prompt:
EditBin /LARGEADDRESSAWARE <yourapplication.exe>
  • A 32 bit application is only allowed a maximum of 2Gb of memory. Using Large Address Aware, you can increase this limitation on a 64 bit operating system.
