Write to Measurement File Creates Corrupt TDMS File
Updated Jul 19, 2018
  • LabVIEW 2017
I am using the Write to Measurement File Express VI in my application to create binary TDMS files. When I build the application into an executable, the output files are blank or corrupt.  If I remove task input into the "DAQmx Task" terminal, the TDMS file is created correctly. Why is this happening?
This behavior occurs because a part of the Write to Measurement File Express VI was not included in the built application.
When you build the application, you must manually include ex_getDaqmxChannelPropertiesCore.vi to the "Always Included" portion of the application build specifications.
This article walks through further explanation of how to manually include a vi to build specifications.
This is due to a general issue where a built application doesn't include a dynamically loaded VI at build time automatically. In this case, you must add it manually.
