Assert REN (Remote Enable) on System Controller
Updated Dec 20, 2022
  • GPIB Instrument Control Device
  • NI-488.2
What does the Assert REN when SC Option in the GPIB Controller configuration pane in MAX do?
Assert REN when SC means that when the ibic command ibsic is used to set the GPIB Controller Card as the System Controller, the "Remote Enable Line" is also asserted.
Sending other GPIB commands like ibrd and ibwrt should not change the state of the REN line.
