Difference Between Current Level and Current Limit
Updated Jul 4, 2018
  • PXI-4110
  • NI-DCPower
The Current Programming Accuracy/Resolution section of the PXIe-4110 Specification Sheet makes reference to a current level and a current limit. What should I use?
The current level setting is applicable only if the output function of the channel is set to NIDCPOWER_VAL_DC_CURRENT. It is the current the device attempts to generate.
The current limit setting is applicable only if the output function of the channel is set to NIDCPOWER_VAL_DC_VOLTAGE. It is the current that the output should not exceed when generating voltage.
