DAQ Module Missing in DAQ Assistant
Updated Mar 27, 2025
When I try to use the DAQ Assistant and choose the desired measurement type, I do not see my DAQ module. Why is this occurring?
There are a couple of possible reasons for this occurring:
As an example, if you are using a Current Input Module but want to measure Pressure, you will not be able to select a Pressure task with this module. You can measure Current and use Custom Scales to work directly with the scaled units of your device.
