Unknown Symbol Compile Error at FP_Open in LabWindows™/CVI™
Updated Jul 12, 2018
  • LabWindows/CVI
  • NI-FieldPoint
When I try to compile my FieldPoint LabWindows/CVI project, I receive the error "Undefined symbol" in my compiler log. How can I troubleshoot this issue?
Here are a few troubleshooting steps:
1. Make sure that the Debug mode in LabWindows/CVI is set correctly. In Build » Configuration, verify that you're in Debug mode and not Debug64.
2. Try manually adding the FieldPoint.fp file to the project. To do this, right-click Libraries » Add, then navigate to the FieldPoint.fp file. This can help if multiple versions of LabWindows/CVI were installed on the same PC at the time of the original FieldPoint installation, as the driver install only applies FieldPoint support to the most recent version of LabWindows/CVI on that machine.
3. Try upgrading to a newer version of LabWindows/CVI and linking the FieldPoint.fp library directly to shared/cvi/bin.
4. Uninstall and reinstall the FieldPoint driver.
5. Completely uninstall LabWindows/CVI and FieldPoint, and then reinstall LabWindows/CVI, followed by FieldPoint.
Note : NI recommends CompactRIO for new designs. Please contact National Instruments if you have questions about the lifecycle of the FieldPoint products.
