TestStand Sequence Is Not Bringing Up the Serial Number Window
Updated Jul 10, 2018
  • TestStand
  • TestStand 2016
  • TestStand 2017
When I click on the "Test UUTs" or the "Single Pass" options to run my TestStand sequence, the UUT Information that asks for the Serial Numbers is not showing up and the sequence is stopping immediately.
Go to the Station Options on the Configure menu, and make sure that the checkbox for "Immediately GoTo Cleanup on Sequence Failure" is not marked, as seen in the following image:
If you have this option selected, TestStand will finish the execution at that step, and go to the cleanup steps of the sequences, causing it to ignore everything from the process model after the step that caused the failure.
