Finding the Right Driver for NI DAQ Devices
Updated Mar 26, 2019
  • CompactDAQ Chassis
  • Multifunction I/O Device
I need to install a driver for NI hardware, because:
  • I have recently purchased a USB, cDAQ, PCI, or PXI device from National Instruments and am currently setting it up.
  • My device does not show up as connected to my computer.
All National Instruments DAQ devices require the NI-DAQmx driver, which can be found online at NI-DAQmx
NI recommends downloading the latest NI-DAQmx driver that is compatible with your operating system, software, and hardware. Drivers must also be downloaded following the correct installation order to function properly.
OS Compatibility
Software Compatibility
  • NI-DAQmx and LabVIEW Compatibility  ​
  • For other software programs, such as TestStand, SignalExpress, or DAQExpress, see the corresponding software readme for compatibility information.
Hardware Compatibility
For the most accurate and up-to-date information, check the NI-DAQmx readmes to see which devices are supported by each version.
Other Drivers
Most devices only require NI-DAQmx. To see if other drivers are required for a particular device, reference the getting started guide for that device.
