What Are the Pinouts of the SCXI-1180?
Updated Aug 28, 2018
  • SCXI-1180
  • SCXI-1302
The SCXI-1180 manual does not list the pinouts for the module, and I'd like to know where to connect wires on my SCXI-1302 terminal block.
The SCXI-1180 pinouts can be found in the following table:
Not all M-Series boards are the same.  Please refer to the M-Series User Manual for device specific pinouts.
For X-Series boards which use a 68-pin connector, check the DAQ device pinouts in the specification document and then compare to the "50-Pin Connector" column in the above table to see if it matches.
