To use a DAQ device, the operating system (OS), driver, and device itself must all be compatible. New DAQ devices work with the NI DAQmx Driver which is compatible with Windows 10 versions 15.5-current,whereas older DAQ devices work with the traditional NI-DAQ Driver which cannot be installed on Windows 10.
You can find out which driver your device is working with in the user manual of the device, or in the driver's
Readme file under the sections "Supported Operating Systems" and "Device Support in NI-DAQmx". These two sections will show you if your particular driver will be compatible with your hardware and OS. To get to the Readme file, select the driver version, and click
View Readme.
You can use the following tool to find out which version of the DAQmx driver will be compatible with your DAQ device and OS:
NI-DAQmx First Available Hardware Support.
