Programmatically Add a Page to a Tab Control During VI Execution
Updated Aug 22, 2023
I need to dynamically displace newly acquired data on a new Tab Control page. How should I program the block diagram, so that the Tab Control on the front panel will automatically create a new page, and display the newly acquired data?
Unfortunately, you cannot get this done under current LabVIEW versions (2018 and older).
Because the pages in a Tab Control is an enum type by nature, and an enum cannot be programmatically edited during a VI's execution. It can only be edited manually when you are designing the block diagram, and each page's existence is fixed after that.
There are two possible methods to make it look like a new Tab Control page is programmatically created during VI's execution.
  • By modifying the visibility of specific pages at run-time. You can implement this method by using Property Nodes, please refer to the following image in detail.
