Interfacing PXI Modules Using C/C++
Updated Mar 26, 2025
  • LabWindows/CVI
  • NI-DMM
 Is there a way to access PXI modules from C/C++ without needing LabWindows/CVI or LabVIEW?
Yes, most National Instrument's cards have C Language Support installed by their drivers.
  1. You need to manually select them during the installation/repair process.
The driver C Language Support also installs different example programs. Look at Related Links for some example programs locations and additional information.
