When installing modules to a service pack version of LabVIEW the modules may show up as being installed for the non-service pack version of LabVIEW; for example, if you install the Real-Time Module for LabVIEW 2017 SP1, it will likely show up under LabVIEW 2017. This is due to versioning of the modules and should not inhibit your ability to activate the module or use it in the SP1 version of LabVIEW.
If you do not see the Real-Time Module under LabVIEW or LabVIEW SP1, ensure you have installed the module.
