Using Second Ethernet Port on NI-sbRIO-9651
Updated Jun 22, 2018
  • sbRIO-9651
I want to use the second Ethernet port on the NI sbRIO-9651 for TCP/HTTP use only because I will connect TCP and HTTP test equipment devices to it. Where can I specify in the LabVIEW project or on the target which Ethernet port to use?
You can achieve this by setting
  • LabVIEWHTTPClient.lvlib.GET.vi address input for HTTP connection
  • TCP Open Connection.vi address input for TCP connection
to the IP address of the test equipment attached to the second Ethernet port.
