cRIO-9045 Shows Up As USB Device in MAX
Updated Jun 22, 2018
  • cRIO-9045
I have a cRIO-9045 chassis plugged into my computer via USB and when I try to connect to it in MAX, I notice that it is under Devices and Interfaces instead of Remote Systems and is is listed as a USB device. How can I fix this?
This issue occurs if you do not have the NI-RIO driver installed, as MAX is unable to recognize the chassis as a cRIO without the RIO driver and defaults to it being a USB device. To fix this, install the appropriate NI-RIO driver. Make sure that you download a driver that is compatible with your version of LabVIEW.
