SoftMotion Geared Axes Become Unsynchronized After Hitting Limit Switch
Updated Jul 2, 2018
  • Kollmorgen Drive and Motor Cable
  • LabVIEW SoftMotion Module
I am synchronizing two motor drives with SoftMotion Gearing, but one of the drives becomes disabled after hitting a limit switch. Re-enabling the drive is required to move the motor again. How do I resolve this?
There are multiple potential causes for this behavior. Try the following troubleshooting steps to resolve the issue:
  • If you are wiring the same limit switch to both drives, consider wiring it only to the master drive.
  • If using Kollmorgen AKD drives, ensure that the settings in the SoftMotion Axis Configuration does not conflict with any settings in the Kollmorgen Workbench software.
