Below are instructions for one way to demonstrate this use case:
Make sure this state transitions to "Start Application".
Now when you run the VI you can select the option to "Open Sequence File" to point to a sequence file of interest.
On the front panel you will now see the steps of that sequence in the Sequence File View Manager Control.
Original example adapted in this article can be found here (Location will change based on TestStand Version) - C:\Users\Public\Documents\National Instruments\TestStand 20XX (64-bit)\Examples\Modifying User Interfaces\Building a TestStand UI with Native Controls\LabVIEW
