Why Does Generate Max Report VI Not Generate A Full Max Technical Report?
Updated Jun 22, 2018
I am using the Generate Max Report.vi to programmatically generate Max Technical Reports but they are different than the Technical Reports I generate from NI Max myself.  Why is this and how do I generate the full report?
When generating a Max Technical Report there are three options, Simple, Custom, and Technical Support Report.  The Generate Max Report VI generates a simple report.  If you want the Technical Support Report you will have to edit the Generate Max Report VI to select the Technical Support Report.
