To add this property, follow the next steps:
- Go to your Block Diagram, right click, Application Control > Property Node
2. After inser the property node, right click on "reference" input
3. Right click on "reference" input, go to Select Class > .NET > System.Net.Mail.SmtpClient
4. Click on "Property" and select "Timeout"
5. Right click on "Timeout" and select "Change to Write"
6. Right click on "Timeout" input and select Create>Constant
7. Set the time you want
