In the Mathematics VIs Palette you can find two subpalettes Ordinary Differential Equations VIs and Partial Differential Equations VIs.
Note that many Mathematics VIs are available only in the LabVIEW Full and Professional Development Systems. If you have the LabVIEW Base Development System, you do not have the full set of the Mathematics VIs. A subset of the Mathematics VIs is available in the LabVIEW Base Development System.
