Does the LFH160 Cable for PXI Switches Have Twisted Pairs?
Updated Jun 21, 2018
  • LFH160
  • PXI-2576
  • PXI-2530B
I've documentation of cables for PXI switches like the LFH200 mention the channel pairs are twisted. I need to use a PXI Switch that requires the LFH160 cable instead and I am unable to find this in the cable's documentation.
There are two versions of the LFH160 cable, one meant to be used with the PXI-2576 and one for the PXI-2530B.
If twisted pairs are required with a PXI-2530B, an alternative is using a front mount terminal block with external twisted pairs.
