Compiler Error When Building a LabVIEW Application
Updated Jun 21, 2018
When I try to build an executable or installer in LabVIEW I get the following compiler error. I have already tried recompiling my VI and doing a mass compile. How do I fix this error so that I can build LabVIEW applications?
  1. If you have recently installed any LabVIEW updates, make sure to reboot your computer after the installation
  2. Try building an executable from a different VI to see if this compiler error is isolated to your program or the LabVIEW environment
  3. If this compiler error happens when you try to build an executable from any program, uninstall and reinstall LabVIEW
