How to Export Sample Clock to The CLK OUT Terminal in LabWindows™/CVI™
Updated Jun 21, 2018
  • PXIe-5451
  • PXIe-5450
  • LabWindows/CVI
  • NI-FGEN
I have a PXIe-5451 device. I need to export the sample clock to the CLK OUT terminal on the Front Panel SMA connector.
How can I do this programmatically in LabWindows™/CVI™?
You can export the Sample Clock to the CLK OUT SMA connector as following:
niFgen_ExportSignal (vi, NIFGEN_VAL_SAMPLE_CLOCK, "", ClkOut );
where vi is he is the ViSession , NIFGEN_VAL_SAMPLE_CLOCK is the signal to route, and ClkOut is the output terminal to export the signal.
For a complete list of compatible sources and destinations, find the device in MAX and use the "Device Routes" tab:
