The above issues can occur when using a PXIe-8370 card that has the original firmware, which is connecting to a computer running NI software released in or after 2016. The issue is fixed by updating to the PXIe-8370 firmware version 2012.07.10.10.
Follow these steps to upgrade the firmware:
- Connect the PXIe-8370 to a computer that uses an earlier version of NI software (15.0 or older).
- Ensure that all necessary software and drivers are installed for your PXI system.
- Download the PXIe-8370 firmware version 2012.07.10.10, and save this to a location of your choice.
- Open Measurement & Automation Explorer (NI MAX) on the computer.
- Select the PXIe-8370 in NI MAX. (NB: If the link cards start to blink red at this step, follow the advice listed in the Additional Information section).
- Click Update firmware
- When prompted, navigate to the folder in which you saved the download from Step 2, and select the .bin file.
- After the firmware update has completed, power down the PXIe chassis.
- Remove the PXIe-8370 card from the chassis.
- Plug the card in again.
