How Do I Connect a PCI-6508/6509 to an ER-16 and Still Have Access to the Digital Lines?
Updated Jul 12, 2018
  • PCI-6509
  • ER-8/16 POD
I found documentation on how to connect a PCI-6508 (PCI-DIO-96) to an ER-16, but how do I access the rest of the digital lines? How would I make these connections with an PCI-6509?
The pin-out of the PCI-6508 is identical to the PCI-6509, so the setup for both cards is the same. In order to connect the digital board to the ER-16, you must use an SH1005050 cable, SC-2054, and an NB1 cable. To access the unused digital lines, you must add two additional CB-50s, along with two additional NB1 cables (See Figure 1). The ER-16 will require an external 5V power supply because the SC-2054 does not preserve a 5V connection to the module. The 5V pin from the digital board will suffice, but you will have to wire from one of the CB-50s in order to use it.
Figure 1 -  Connection diagram for the PCI-6509 and ER-16
