Archived:Cannot Create LabVIEW VI in Vision Assistant 2009
Updated Mar 30, 2019
  • Vision Assistant
  • LabVIEW 2009
Using Vision Assistant 2009 on Windows machine and would like to use the "Create LabVIEW VI..." code generation feature.  However, nothing happens when I click it.  Why isn't the code generation feature working correctly?
There is an issue with the code generation feature in Vision Assistant 2009.  National Instruments has created a patch to fix this behavior.
Please download the attached VisionAssistant2009Hotfix.exe and run the installer to resolve the issue.
This affects users with Windows 2000, Windows XP without .NET support installed, localized (non-English) Windows XP and localized Windows Vista operating systems.
