VeriStand: Programmatically Create Aliases in System Definition File
Updated Jul 10, 2018
  • VeriStand
Is there a method to programmatically create aliases in the system definition file for VeriStand in LabVIEW?
A LabVIEW wrapper for the VeriStand .NET API exists. One of the supported functions is "Add Alias": VeriStand Simple System Definition API
You can also achieve this by using the VeriStand .NET API.
For an example of how to do this please see the attached VI. The VI attached allows the outports of the model to be in a folder. This is why it is using the FindChildrenByGUID property instead of the GetOutports
