Does the USB-6211 Take Encoder Measurements?
Updated Dec 16, 2022
  • USB-6211
  • I am trying to take angular displacement measurements for a torsion application and have encoders for these measurements. Does the USB-6211 I have work to take these measurements?
  • I would like to use a quadrature encoder to take linear displacement measurements, can I use this device with my encoder?
Yes, taking encoder measurements calls for counter input channels on your DAQ device. From the USB-6211 Specifications you can note that the device has 2 counter / timer channels and that it can be used with X1, X2 and X4 quadrature encoders with Z-channel reloading, as well as with two-pulse encoders.
In addition, NI MAX shows that the device supports the creation of counter input tasks for angular position and linear position measurements, as seen on the following image:
Other considerations may include ensuring that the channel count, clock frequency, device accuracy, and resolution are sufficient for your application.
