I am using a LabVIEW VI inside my TestStand sequence, which uses a cluster to pass data to and from it. I have declared this cluster as a Custom Data Type, per: How Do I Pass Data Between a TestStand Container and a Cluster in a LabVIEW VI?
However, after making my Custom Data Type, and selecting it in the TestStand's LabVIEW Adapter configuration, I get an Evaluation Error:
"No Corresponding Subproperty in Argument.
This value will cause a run-time error."
