Block Diagram Events/Methods/Properties Names Do Not Match Actual Behavior.
Updated Sep 10, 2018
  • LabVIEW 2015 SP1 Professional
In my newly installed LabVIEW 2015 names of some of Block Diagram objects are mixed. It looks like they were replaced with generic names. For example:  Event Structure instead of having Timeout field has Selection Change field which behaves as it would be Timeout
Below print-screens present the disrupted and expected block diagram objects naming.
One known way of resolving this issue is uninstalling LabVIEW, consequently removing manually LabVIEW folder ( X://Program Files (x86)\National Instruments\LabVIEW 2015) and installing LabVIEW back.
