このコンテンツは設定された言語で表示できません。
Error 1003 When Trying to Programmatically Launch a VI Using CAN Functions in Executable
Updated Mar 17, 2023
  • NI-CAN
When i am trying to programmatically launch a VI using CAN functions with an executable file built using the LabVIEW Application Builder, I receive following error message:
Error 1003 occurred at Invoke Node in Dynamic Call.vi
When programmatically launching a VI which has NI CAN functions (for example, using an Open VI Reference function from the Application Control palette and then using an invoke node to launch and run a VI), you must add the VI you are launching programmatically as a dynamic VI in the LabVIEW Application Builder.
The Source Files category in the LabVIEW Application Builder allows the addition of dynamic VIs in the Always Included window.  Please note that in order to use NI-CAN functions in an application, you must have NI-CAN installed on the application's target machine.
