Generate Report Using HTML Template
Updated Apr 16, 2019
I am using Report Generation Toolkit for Microsoft Office and I want to generate reports using the HTML Template. Is it possible? If so, what are the steps to do the same?
It is possible to create reports using the HTML Template : Report Generation Using HTML Template
Above is the link to a post on NI Discussion Forums that details how to use the HTML Template for generating a report.
It is also worth going through the other reporting options for LabVIEW Data. The link for the white paper is available in the Related Links section.
