Example for Getting Started with Adapter Module NI-5734
Updated Jun 21, 2018
  • NI-5734
  • FlexRIO
I've started to work with the NI-5734 (Digitizer Adapter Module for FlexRIO), National Instruments provide any example code with it?
When the FlexRIO driver is installed (you can download the latest version from here), from NI Example Finder you can find two examples:
1. NI-5734 - Clock Select.lvproj: This example demonstrates how to select the desired clock configuration for the NI 5734 adapter module. This example continuously acquires records of analog input data from the NI 5734 adapter module. It allows you to select an AI channel, trigger type, and record size.
2. NI-5734 - Getting Started.lvproj: This example transfers a finite number of samples from the FPGA target to the Host using a stream.
If you are interested in program a digital downconverter see the document: A Digital Downconverter for the NI 5734.
