Error 1967362038 When Running Open and Verify Variable Connection
Updated Jun 15, 2018
I am creating multiple shared variables using a For Loop. Then I use an Open and Verify Variable Connection .vi each iteration to verify that they have been created. I don't receive errors for the first variable, but the second variable returns Error -1967362038 from Open and Verify Variable Connection.
You must create all your shared variables first, then Commit Shared Variables after all variables have been created, and before trying to open connections to any of your variables. See the attached VI for an example of this procedure.
