Timeout Error -307672 in VeriStand
Updated Dec 14, 2021
  • VeriStand
When I try to deploy my VeriStand project, I get the following error in the deploy log:
Error -307672 occurred at NI VeriStand Gateway.lvlib:Veristand Server Wrapper.vi >> NI VeriStand Server.lvlib:NI VeriStand Server.vi
Possible reason(s):
NI VeriStand:  One or more targets failed to start within the specified timeout. Verify that any start trigger or clock signals are configured correctly.
and I also get the following error from a running status dialog box in VeriStand:
Details:
Error -307663 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
NI VeriStand: DataServices.lvlib:ERunConfiguration.vi.ProxyCaller >> DataServices.lvlib:ERunConfiguration.vi:2
This error is can be caused by a hardware timeout. Following these steps can help extend the timeout period and may help overcome the error.
For VeriStand 2019 or later
  1. Open your project in VeriStand.
  2. Double click on the .nivsprj. This will open the project at the middle pane of the editor.
  3. Select the Document tab at the right pane of editor and find Wait milliseconds.
  4. Change the value of Wait milliseconds 120000 ms (Default) to 180000 ms.
  5. If it doesn't work, you can try with higher values like 200000 ms, 220000 ms, or more.
For VeriStand 2018 or earlier
  2. Right Click on your main project and select Properties.
  3. Click VeriStand Gateway and find Wait for specified timeout Timeout.
  4. Change the value of Wait for specified timeout Timeout 120000 ms (Default) to 180000 ms.
This timeout error can also be caused when your hardware goes into a bad state. You will see this deployment timeout error because your project cannot correctly communicate with hardware it is trying to communicate with. To determine if this your behavior:
  • Examine your hardware.
    • If you have CAN or XNET cards, are any ports showing as active when they should not be? Consult your user device manual for what LED signals mean.
  • Narrow down your project to include fewer pieces of hardware.
    • Start with a blank system definition file and see if you can successfully deploy that.
    • Add in pieces of hardware, models, or custom devices to the sysdef one at a time until the error returns.
