Create an Array in DIAdem Using Script
Updated May 12, 2026
  • DIAdem
In DIAdem script function, I already know the typical method that imports measured tdms data. But how can I make an array that I define using script?
DIAdem can automate the process by using Visual Basic script. VB script is a universal programming language. Any function you need can be searched through any web browser.
To make an array using DIAdem script, please refer to the following example.
Figure 1 shows how data groups and channel data are generated. Figure 2 shows VB script that makes an array and channel.
Figure 1 - DIAdem VIEW
Figure 2 - VB Script
